I’m trying to define cross section with JSON to GH and from GH to Sofistik. Cross section works fine and line reinforcement also but I can’t get perimeter reinforcement to work. I tried the definition with line reinforcement and got it work and then removed it from the script.
Grasshopper does read the JSON file and draws the cross section but the it doesn’t draw the reinforcement. What’s wrong with my script?
The answer seems correct. Only issue i had was regarding the units. The pier loop variables seems to be in cm, but your unit is set to meter. Also the perimeter reinforcement variables seem to be in meter. So changing the variables to the following would be the correct way:
“Variables”: { “h”:3.0, “b”:1.25, “r”:0.1}
Edit: Im using the 2023 version, maybe thats why i had to change it
