Is there a way to check if convergence was achieved by accessing the database?
80/HC lists the number of iterations for a given loadsteps. So based on the iterations and max number of of iteration you can check but in the case of convergence in the last iteration this option would yield an incorrect result. Is there a different way?
Yes
rec @LC_CTRL and key @(12) gives you number of iterations to achive convergence or 0 if it did not converge
hello do you know by any chance what criterium 2 and 3 mean?
