I wish to inquire on how to impose self-weight to the structural model.
For your information, I have modelled my structural model in Rhino software. However, I was not sure on how to impose the selfweight to my model. (Ps: I was known that if the modelling is done in SofiPlus, the selfweight could be imposed by editting the Load Case Manager in SofiPlus. However, for modelling in Rhino, is there any way to impose the selfweight to the modelled structure?)
And if there is a need to use the Teddy script, I wish to enquire on how to write the script for imposing the selfweight.
If it helps … As mentioned … you can “cheat” and apply/model free loads in Sofiplus, export to SSD and from SSD export to teddy file. Then export model from rhino and copy paste free loads teddy task into SSD
Save all tasks as text: All the input tasks gets converted to a .dat (teddy file). Doesn’t cover sofiplus input
Tomaz used the database export feature (see picture below). There you can convert what is in the cdb (database) to a corresponding text input. E.g. if you have a sofiplus model this can give you a text version of it.
After that you start working in the text files and start recognizing commands as you go.
