I am working on a university homework which is a 3 supported composite bridge. I would like to make wedging at the middle support, so i made variables on the axis and on the cross section. But it seems like the variable doesn’t import the value from the axis.
Any solution?
According to your first picture, the axis variable is imported correctly.
Have you tried defining a Cartesian reference that includes the #HEIGHT variable?
If not, follow the steps outlined in the video below.
If you have no clue how to implement the variable cross-section, you can upload your project files (.ssd and .dwg). I updated your user status.
