Hi, I am trying to model this beam with Euler Bernoulli but it was imposible to put the negative moment in x=0, the error is “Load on reference SPT” - How can I model it? Thank u
Hi abusma.
the error indicates a mixing of the units. The first message says that structure points are being merged because they are too close to each other (e.g. number 1 and 3).
The second message says that loads are not applied because the loaded point does not exist (e.g. number 3).
Check your system units and the distance between the points.
Birgit
