I would like to be able to retreive the values of the vertical acceleration as a function of time of certain nodes in my bridge model after running a time step analysis with DYNA, but can’t figure out how to do this.
I used to run a time step analysis with ASE in which I was able to view plots of the acceleration in the ‘Report Browser’, and in which I was also able to obtain a list of the acceleration values of any node for each time step in the ‘Result Viewer’ (see screenshot below). However, I recently found out that ASE is not suitable for a dynamic analysis and I have to use DYNA instead, because I want to analyze the damping of the bridge. The problem is that when I use DYNA, I’m no longer able to obtain the acceleration results as before.
My Teddy file:
Puurs.dat (40.9 KB)
As always, any help would be greatly appreciated.
