When switching between different load case, only the active layer (1: Beam elements) use the current selected load case 40200, the inactive layer (2: Nodes) still use the previous load case 40100.
I’m miss this functionality too. There should be an tick like “use Load case of previous layer” like scale option has.
There is such feature:
However it does not work when you want to switch loadcase and designcase at the same time.
Any changes you made in properties, you can apply to entire picture or graphic.
