How to give displacement of a node in local coordinate system
In Sofistik, the displacement of a node can be done only for the global coordinate system for exaple using WXX,WYY and WZZ.
Is it possible to define the displacement of the node in lokal coordniate system?
Thanks in advance.
Define spring (point link) with very low value at the point and in the direction of wanted displacement. You can superimpose and show displacement in local direction of spring.
