Where can I find in Sofistic the corresponding reactions in the support node for load combinations? For example: MY max
MZ resp.
MX resp.
PZ resp.
PX resp.
PY resp.
MY min
MZ resp.
MX resp.
PZ resp.
PX resp.
PY resp.
Please use the result set workflow.
Result Sets, are designed to get corresponding results.
Please see the online video BRIDGE DESIGN TRAINING #09 and goto chapter “CADINP Input for Result Sets” Time: 1:29:37
With newer versions, from version 2022 on, you can create bridge bearings as result sets inside the SOFiPLUS workflow. There is a German language video to show this workflow.
For further information according RSET in general please read the SOFiMSHA manual, chapter 3.35
I used the RSET command in the SOFIMSHA module as you suggested, but I use the MAXIMA module in Teddy, and the movie uses the ELLA module and the CALC command. What should the code look like in the SOFIMSHA and MAXIMA modules to use the RSET command and get the corresponding internal forces?
