Hi. I want to draw This 2D Frame with prestress. But when i create tedon in the column. It error when i export to SSD.
This exceicise
And i draw it
When i export to SSD.
This exceicise
From the attached pictures, I assume that you have probably used the axis, defined in the system, to assign the tendons. The elements of the frame are not assigned to the axis, which probably causes the error; and furthermore, the columns are also perpendicular to the axis.
I would advise you to use Tendon (draw) option from the Beam PT:Create and Modify set of options in the Sofiplus sidebar, instead of PT Editor (Spline Geometry). Afterwards just select the structural line to which you would like to assign a tendon, define the tendon options and draw the geometry.
I hope this helps.
Thanks. I really appreciate.
