I am trying to introduce hinges along some SLN inside two SAR in sofimeshc
I define the SAR using SARB with points and then i use SARB again to define inner boundaries with SLN and hinges using FIX.
The problem is this works only in the second SAR i define but not in the first. However the syntax is the same in both.
Can somebody tell what i am doing wrong?
Thanks
PROG AQUA URS:1
HEAD
NORM EN 199x-200x-bridge
UNIT 0 $ Units in m
CONC 1 C 30
STEE 2 S 500
STEE 10 S 275
PROF 1 TYPE IPE 600 MNO 10
PROF 2 TYPE IPE 300 MNO 10
+prog sofimshc urs:6
head
unit 5 ; syst spac GDIV 10000
CTRL MESH 3 ; CTRL HMIN 0.3 ; CTRL TOLG 0.001
echo full full
$ geometry points
spt no x y
1 -8 -8
2 8 -8
3 8 8
4 -8 8
5 8 0.025
6 8+7.075 0.025
7 8+7.075 8
spt (11 16 1) x (-6.25 2.50) y -8.0
spt (21 26 1) x (-6.25 2.50) y -5.0 fix pp
spt (31 36 1) x (-6.25 2.50) y 0.0 fix pp
spt (41 46 1) x (-6.25 2.50) y 5.0 fix pp
spt (51 56 1) x (-6.25 2.50) y 8.0
spt (17 18 1) x (10.075+0.5 2.0) y 0.025
spt (27 28 1) x (10.075+0.5 2.0) y 2.025+0.25 fix pp
spt (37 38 1) x (10.075+0.5 2.0) y 6.025-0.25 fix pp
spt (47 48 1) x (10.075+0.5 2.0) y 8.000
spt no x y
61 -8 -6.25
62 -3.75 -6.25
63 3.75 -6.25
64 8 -6.25
71 -8 -1.25
72 -3.75 -1.25
73 3.75 -1.25
74 8 -1.25
81 -8 1.25
82 -3.75 1.25
83 3.75 1.25
84 15.075 1.25
91 -8 6.25
92 -3.75 6.25
93 3.75 6.25
94 15.075 6.25
95 3.75 3.75
96 15.075 3.75
$ structural lines
sln (11 16 1) npa (11 1) npe (51 1) sno 1 grp 1
sln (17 18 1) npa (17 1) npe (47 1) sno 1 grp 1
sln (61 63 2) npa (61 2) (62 2) sno 2 grp 2
sln (71 73 2) npa (71 2) (72 2) sno 2 grp 2
sln (81 83 2) npa (81 2) (82 2) sno 2 grp 2
sln (91 93 2) npa (91 2) (92 2) sno 2 grp 2
sln 95 npa 95 96 sno 2 grp 2
sln no npa npe sno=2 grp=2
1 1 2
2 2 5
3 5 6
4 6 7
5 7 4
6 4 1
7 3 5
loop#j 3
loop#i 3
sln 21+#i+10*#j ; slnb xm -5+5*#i ym -5+5*#j r 1.0 nz 1.0
endloop
endloop
$contornos pilotes 0.8
loop#j 2
sln 27+10*#j ; slnb xm 11.075+0.5 ym 2.025+0.25+3.5*#j r 0.4 nz 1.0
endloop
$ first SAR where internal boundary with hinges does not work
sar 1 mno 1 t 230[mm] tx 300[mm] ty 200[mm] txy 200[mm] td 200[mm] grp 3
sarb na ne type=out
1 2
2 3
3 4
4 1
sarb type in nl 61,63,71,73,81,83,91,93,95 fix mx $ definition of the hinge
$ second SAR where the hinges work ok
sar 2 mno 1 t 230[mm] tx 300[mm] ty 200[mm] txy 200[mm] td 200[mm] grp 3
sarb na ne
5 6
6 7
7 3
3 5
$ some voids
sar void
sarb nl (21 23 1)
sarb nl (31 33 1)
sarb nl (41 43 1)
sarb nl (27 37 10)
