Help with sending .dwg
I’m working on my thesis and using Soficad to draw reinforcement plans. I would like to send my mentor the .dwg file, but I’m having issues with parts of the drawing not displaying properly on his end.
When I send the file, a lot of the content is missing or not visible. I’d like to ask – how can I export or save the .dwg so that everything I’ve drawn is clearly visible, without converting it to PDF (since my mentor insists on receiving the file in .dwg format)?
Thank you in advance!
3
with the input of SOF_BASE_EXPLODEALL in the command line you can change the SOFiCAD objects to AutoCAD elements.
Hello jojo,
using your mentor also Soficad and if yes which year-level is your and his cad-program. If no, he can use eventually Sofistik Object Enabler 202x (X= 3 - 5).
Perhaps this is an option.
If you solve the problem, please share the solution.
Thanks a lot and have a good week.
Thx, people… SOF_BASE_EXPLODEALL command worked like a charm.
