Hello!
I am new to Sofistik - Rhino/Grasshopper modeller. Since now, I used Sofiplus.
How do I create a structural area with variable thickness?
Does code have to look something like this?
Kind regards! Nejc
Just give it a try. Start the calculation and open the system visualization. I think you have to set the thickness of the structural area to 0 m.
For a detailed description you should look at our grasshopper online manual.
https://www.sofistik.de/documentation/2020/en/rhino_interface/grasshopper/components/EdgeAttributes.html?highlight=edge
Hello.
I found the solution. I had to define all necessary object parameters (number, group, thickness, material, reinforcement material).
Otherwise, you cannot get a structural area with varying thickness.
Have you tried to used a data tree as input? Using that does not seems to work for me…
