Graphic 2024 - Use of results layout from previous save
I have multiple analysis of similar components and want to print the results from Graphic. The results are of similar areas.
I know 2 methods to do this. Is there another method?
  1. Copy the .gra file and rename it to be same name as the .sofistik calculation file. Click on Graphic icon in SSD to open.
  2. Start teddy from graphic to get the code for the current layout. Create a task in the new calculation and paste the code and run it.
I think for example
#include C:\test\test.gra
or
+apply C:\test\test.gra
in an SSD task will use this gra-file to create graphics with the current cdb-file.
