Extract internal forces in shell model to apply as external loads
I have two quad models, model A and model B, where model B is a cut-out section of model A.
In model A I calculate internal forces. Now I want to apply these internal forces at the cutting planes as external loads in model B.
My first idea was to get the nodal forces in model A and then apply nodal loads in model B. It would be a clear and comprehensible approach but unfortunately I can’t find nodal loads as results in the database. There’s membrane forces per node but then I need geometry information from the neighbouring quads to calculate the resultant forces.
The picture shows external loads and the resulting membrane forces per node. I can calculate the nodal forces for the edge nodes with 800 kN/m x 0,005m=4 kN and for the inner nodes with 800 x 0,01m=8 kN but my actual model is of course more complicated and 3D.
Does anyone have an idea what would be the best approach for this?
Joachim
If anybody is still interested here’s what I did in the end: I read the membrane and shear forces in the nodes at a section using the Python API to read CDBs and then manually integrate the forces assuming linear distribution between the nodes. From that I get global forces in X,Y,Z per node. To get started with the Python API I recommend this video: https://www.youtube.com/watch?v=l8lc1vV3Tto Best regards Joachim
In fact you can get nodal forces for quad elements:
Okay, I see. Here’s an idea: For the support nodes of Model B, extract the displacements and rotations from Model A and apply them as as support displacements and rotations in Model B.
In more scientific words apply Dirichlet boundary conditions instead of Neumann, if I use English terms correctly.
