Hello to the Forum,
could someone indicate where the tendon geometry is saved when using the geox command of the TENDON module? I have tried it many times without success because I do not seem to find a .txt file or something of this kind in the project folder afterwards.
Is there any other way to export the tendon geometry (coordinates S,U,V or X,Y,Z) in a *.dwg or *.txt file so as to be able to use in a CAD or BIM program?
Thank you very much in advance!
Kind Regards,
Dimitris
