Export Membrane 2D Cut Pattern
I’m currently doing a project for my master thesis and I wanted to export a 2D cut pattern membrane. I was only able to use TEXTILE to export a 3D pattern.
Is it possible to export the 2D layout cut pattern with Sofistik?
Thank you.
The 2D cut patterns are saved within the SOFiSTiK Database .cdb. In order to export the relaxed membrane elements, you have to open SOFiPLUS(-X) and import the .cdb with the command “SOF_G_importcuttingareas”.
MicrosoftTeams-image
Exported results of the TEDDY example “textile > english > textile1_tennishall.dat”:
Further information can be found within the TEXTILE manual.
SSD / TEDDY > Help > User Manuals > All Manuals… > textile > chapter 2.8 Import Export
