Error nr. 12108
Hello all,
Working with Teddy, i get the following error after running PROG SOFIMSHA :
error no. 12108 ; input line: 6
Item at position 9 multiple defined
If a literal item to be specified is identical to the name of an item,
please quote the Literal with apostrophes
My input is:
Its hard for me to understand the error explanation although it looks like a simple syntax problem. Is the problematic line 6, the one with END?
I would appreciate any feedback on the topic.
Best,
Georgia
Hi Georgia,
In your code you are using the command “CM 1000” twice and, hence, the error “Item at position 9 multiple defined”.
