The reason why I am writing refers to a problem I am having with MAXIMA in sofistik. The error reads +++++ error no. 35 in program MARY (TYPE SIG or TAU without definition of SELE makes no sense). I have tried to change the implementation of loads but still this error continues. What could be the reason behind this?
Thank you
Have you defined a cross section point for the calculated cross-section (1 Girder)?
If you want to superimpose stresses, you have to tell the program at which cross-section point (stress point) the superimposition should be performed.
Therefore, check the names of the stress points in the result viewer and select one of them in the superposition manager task.
