When I run the analysis for design ULS, it comes out the error message as below:
+++++ error no. 468 in program BEST1
No elements found for design (may be material is not concrete CONC)
What does it means?
Thank You.
What does it means?
Thank You.
Either you forgot to specify which elements should be designed (e.g. which group) or your elements have the wrong material definition
