I defined two different sections of a tapered beam, but while processing it to SSD, it shows an error. I am doing it the same way as it is given in the training lecture as here (Post-Tensioned Concrete Composite Bridge - SOFiSTiK FOR YOU) I tried it in different SSD versions, but the error is the same. Also, I cannot see the conceptual view of the tapered section.
Dear himes799,
unfortunatley you did not post the error message you got, and also no screenshot to fully understand your problem. This is mandatory to get a useful answer in this forum.
My guess ist, that the two cross sections are not identical in geometry, number of points and order of point definition.
Please check that your cross sections are absolute identical.
In case of further questions try to explain your problem in a way, that someone else can understand it ![]()
