Actually, the load model you selected, “LM3 900 150”, is a load system composed of 6 axles of 150 kN each (6 × 150 = 900 kN).
In your case, with the load you’ve defined, it’s not necessarily listed in the ELLA catalogue. If that’s the case, you can define it manually using TEDDY with the “TRPL” record (Point Load of Load Train).
Hello.
Thank you, i figured it out with your input.
I am using Eurocodes, danish annexes.
Although i am still not sure i understand the input syntax. I am defining my load values, but when tracing the loadpositions, random values seems to be used for the load train.
These are the values generated from this code, see the last 7 load values. I have added a value of 50, which shows up as two values of 18,7 kN.
LC 1211 TYPE NONE TITL 'kl.150'
TRAI USER WIDT 3[m]
TRPL P 68.6 BW 0.6[m] LW 0.2[m] NW 2 B 2[m]
TRPL P 68.6 BW 0.6[m] LW 0.2[m] NW 2 B 2[m] A -1.4[m]
TRPL P 93.2 BW 0.6[m] LW 0.2[m] NW 2 B 2[m] A -3.2[m]
TRPL P 93.2 BW 0.6[m] LW 0.2[m] NW 2 B 2[m] A -1.4[m]
TRPL P 174.6 BW 0.6[m] LW 0.2[m] NW 2 B 2[m] A -6[m]
TRPL P 174.6 BW 0.6[m] LW 0.2[m] NW 2 B 2[m] A -1.4[m]
TRPL P 50 BW 0.6[m] LW 0.2[m] NW 2 B 2[m] A -1.4[m]
