Dynamo with SOFiSTiK Bridge
Hello.
I start this topic with the intention of talk about some aplications of Bridge Modeller with dynamo, i am wondering about:
1.- You can put using dynamos placement along Axis. (import with xml for example)
2.- When you create repeat famlies how to add parameters in the elements example area, volume.
Thnaks for your help
This is a sample script:
Do you have an example script on how to create an axis in dynamo interface? I couldn’t figure out how to create an axis (geometry, placement, etc).
