Hi everyone,
I am designing a footbridge under dynamic responses, and I want to know if it is possible to save the eigenfrequencies in a variable or file and import them automatically in the dynamic analysis program, in Teddy text programming
Because right now I’m supposed to run my code and find the frequencies and enter them manually in my dynamic program.
With which dynamic program are you working and why aren’t you using SOFiSTiK?
SOFiSTiK solves a variety of different dynamic tasks. Just have a look into our TEDDY examples.
TEDDY > File > Examples > DYNA
If you really want to extract the eigenvalues out of the database, you can use the @key command. In order to access the eigenvalues you should have a look at the CDBASE. However, this application is very advanced.
TEDDY > Start > Database Tools > CDBASE Help > SOFiSTiK Data > Dynamic Analysis Data > Eigenvalues (@Rec 090/00)
Could you please give me more details on this by an exemple?
I read the help, but I really didn’t understand how to extract my eigenvalues and store them in a variable by @key command
