I have followed the workflow and ended up with the following code:
+PROG FEABENCH urs:114.1
HEAD Dynamisk analyse
TASK TYPE MLT
$ECHO DTC FULL
ECHO FULL yes
GRP NO - FACS 1 FACM 1 MODD 0.026 FRQ1 22.29 FRQ2 45.27 $ Damping definition
$ FRQ1 and FRQ2 signifies the range of interest for the frequencies.
$ Typically FRQ1 is the first bending mode of the structural part in question, or the sctructure and
$ in the SOFiSTiK video they choose FRQ2 as the 3rd bending mode, which indicates that you should consider
$ both frequencies according to the structural part in question
LC 499000
STEP TYPE GENA RHOI 0.8 TVAL AUTO DT AUTO LCR CONT INT 10
DTC ETYP NODE ITEM AG ROI ALL FMAX 45.27
MOVL LCT 104 TRCK ‘GAX’ ID “DYN2” V 63.89[M/SEC] LDA 0.6 LDB 0.5 TDIR POS STYP S SVAL STRT YEX 0
HIST ETYP QUAD ITEM MXX ROI 4000934 HC 500000
EXTR ETYP QUAD ITEM MXX XTYP MAMI LCR 500000
When I run it however, I get the following error message:
Here is an image of the culvert roof with the relevant axes’.
Why do I get this error message?
There does not seem to be anything wrong with the code as I have compared it with the video from the link I provided.
I have tried several axes’, but they all get the same error message. All the axes are created using Teddy, and defines using GAX, so they are main axes’.
You need in all cases a node sequence along the chosen axis DYN2.
In SOFiSTiK tutorial there is one, because there is only one superstructure and therefore there are structural lines along this axis that build this node sequence.
LET#minv 403.6 $ Iht. vedlegg c) TRV
LET#maxv 2301.2 $ Iht. vedlegg c) TRV
LET#dv 2 $ Increment for speed steps [m/s]
LET#N_v (#maxv-#minv)/#dv+1 $ Number of velocity steps
$ Dynamisk analyse
LOOP#i 3
LOOP#j 5
LET#V #vc(#j)/3.6
TASK TYPE MLT
ECHO OPT FULL VAL YES
GRP NO - FACS 1 FACM 1 MODD 0.0255 FRQ1 42 FRQ2 380 $45.27 $ Damping definition
LC 50000+#i*1000+#j*100 $ Choose base load case without any loading
STEP TYPE GENA RHOI 0.8 TVAL AUTO DT 0.005[SEC] LCR NONE
DTC ETYP NODE ITEM AG ROI ALL FMAX 42
MOVL LCT #train_lcs(#i) TRCK SLN ID 1 V #V[M/SEC] LDA 0.5 LDB 0.5 TDIR POS STYP S SVAL STRT YEX 0
HIST ETYP BEAM ITEM MY ROI 10001 HC 55000+#j+#i*10 TITL '#Train_titl(#i), #V m/s'
EXTR ETYP BEAM ITEM MY XTYP MAMI LCR 56000+#j*2+#i*10 TITL '#Train_titl(#i), #V m/s'
ENDLOOP
