Hello, how can I change the dimension text size in Graphic (WinGraph)?
2in wingraph go to Edit>Dimension lines>Properties>in command window type text height
Hey! I was hunting through the specific dimension properties for a while, but looking at the global system parameters makes way more sense. It’s a lifesaver when you’re trying to get the drawings to look consistent across the whole project.
