Is there a way to see when a cross section is no longer used and a way to easily get rid of those unused sections?
kind regards,
kind regards,
Hi Joris,
The only way I can think of at the moment to remove a cross-section from a database is:
Delete a cross-section and run the calculation, if an error pops up, then the cross-section is required.
Something like this:
P.S. Of course make a backup before you delete cross-sections.
Kind regards,
Smiljan T.
Thank you, this works fine.
You can avoid the errors by executing the ‘summary of masses’ task first.
If a cross section is not mentioned in the report, it is not used in the model.
