Simple question. How do I delete all calculated design cases, so I dont need to export model from sofiplus to ssd again to delete them that way?
Thanks Tomaz
Thanks Tomaz
Hello Tomaz
You can delete a specific loadcase with a new sofiload calculation and the command:
LC NO 1 TYPE DEL
If you want to delete all loadcases, you have to include all loadcases to the command.
LC NO (8000 8010 1) TYPE DEL $Deletes all of the loadcases between 8000 and 8010
I think you misunderstood me. I want to delete design cases I calculated with aqb or bemess. Not maxima or ase loadcases.
Thanks.
Ah I’m sorry. ![]()
In BEMESS this is possible with the command:
CTRL RMOD DELE LCR 1,2
Hello Frederik,
continuing the above topic, I have 2 questions - how to delete (using Teddy or from SSD)
Regards
You can delete the design results with the help of the modul SOFiLOAD.
+prog sofiload
!*!Label delete LCR 5
lc 5 TYPE DEL
Please note, however, that you also delete the load cases with the same number (here 5).
