i need to ask how can i define cyclic loading on shear wall to check till failure using sofistik whether teddy or SSD ?
You could try to use the command FUNC within SOFiLOAD. Since I don’t know your exact task, I can’t give you a good solution either. Look through the SOFiLOAD example and the corresponding TEDDY examples.
SSD / TEDDY > Help > User Manuals > All Manuals… > sofiload
TEDDY > File > Examples > sofiload > english > …
I recommend the following YouTube video for the shear wall design.
