I’m working on a Steel Frame project where I need to incorporate haunches in the beams, as shown in the pictures. To achieve this, I created the required cross-sections in Sofiplus and now I’m trying to utilize them in Grasshopper. According to the Command Structural line, the cross-sections need to be named with a dot (.) between two numbers to enable interpolation.
However, I’m encountering difficulties in achieving the desired results. Despite following the naming convention, I’m unable to successfully interpolate the cross-sections. I would greatly appreciate any insights or suggestions regarding what might be causing this issue.
Hi Balhus,
the error message you are getting is because sofistik is having issues interpolation between the two sections. I would recommend making a copy of one cross section, then modifying this section to what you need. You can read a little more here:
