Hi there,
I am currently going through the crack width report generated for my problem.
Although Sofistik says the check passes for the given reinforcements I can see exceedences in the maximum utilisation. Is there a threshold set in the software to ignore failures below say 20%? Is the crack check indeed failing?
Thanks in advance.
