Converting Structural Elements to AutoCAD Elements
Is there a way to convert structural elements to AutoCAD elements? For instance a curved structural line along an axis to an autocad curve. Some operations on SofiPlus-X are only possible with Autocad elements therefore it would be really helpful for me.
Thanks
There is no direct command for this. But you can use the ‘spline’ command to trace any curves/axes and draw them as an AutoCad spline (01a.jpg). Use the ‘next’ snapping option (in german it’s “Nächster Punkt”, see 01b.jpg).
Hope, this helps.
Jost
Yes, definitely helpful. Thanks!
