Is it possible to model contact with sofistik? something such as surface to surface contact or edge to surface contact?
Hey, I guess you can use springs or rigid bodies
if you want to connect to structural areas you can use command SARS.
After the first meshing start new sofimshc modul with:
PROG SOFIMSHC
HEAD
SYST REST
SAR -1 $changes the setting for the structural area number 1
SARS REFT >SAR REF 3 CA 1E6 CL 100 $links sar 1 with sar 3
After linking you need to remesh the system:
+PROG SOFIMSHC
HEAD
SYST REST
CTRL MESH 1
Hope this helps
