ConstructionStage with Spring supported
I am modeling a structural system according to the construction phases. My structure includes pile systems and spring supports. However, when I run the load test according to the construction stage analysis, instability occurs with the spring supports. How can I fix this?
You have to probably add torsional support for piles.
thank you sir, I did it.
