Hi, I am a beginner with sofistik, and was hoping someone could help me in how to define compression only springs for a line element.
There is guidance on how to define compression only for an area element and similar posts on here describe needing to use work laws. Could anyone describe the process if I wanted to use 50,000 kN/m springs.
Thankyou
Dear Alex,
simply define a new work law using the SSD task “Work Laws for Springs and Implicit Beam Hinges”
Then define the bedding for your structure line and apply the before defined work law.
Thats all
Cheers Martin
Thanks Martin, that works perfectly
Hi Martin,
What if I have already defined a spring in sofimsha and I want later to assign the work law in a teddy code.
Do you think this works?
spri NO prop MNO …
mod type spri grp …
Thanks
