hello, in my project I work with the BAEL standard. How can I make the combinations in this case? Knowing that when I try to add traffic overloads they are not displayed
Hello SARA,
in the NF BAEL design code there are given several actions combinations where different factors are assigned to the actions.
The action combinations can be done in the program MAXIMA with explicit defined combinations, e.g.
COMB NO 103 EXTR EXPL BASE 4100 TYPE DESI TITL “Combinaison fondamentale 1”
ADD G FACU GAMU FACF GAMF
ADD QB_A FACU 1.5 FACF 0
ADD QB_B FACU 1.5 FACF 0
ADD QB_C FACU 1.5 FACF 0
ADD W FACU PSIU FACF 0
ADD S FACU PSIU FACF 0
SUPP 103 …
The input definition is also possible in the SSD task ‘Combination Rules’. Here preset action combinations are available. A new combination can be defined via button ‘Combination Rule’ → Insert explicit combination rule.
In this case the actions get an unfavourable and a favourable factor. With the literals, e.g. PSIU = gamma-u*psi0, the values which are saved in the cdbase for the action are used.
The actions have to be defined with the program SOFiLOAD or the task ‘Action Manager’.
The initial load cases are assigned in MAXIMA automatically to the corresponding action. The program MAXIMA determines during the superposition if the initial load cases act unfavourable or favourable and allocates the right factor for each load case.
For the superpositions the initial values have to calculated (program ASE) because MAXIMA superimposed internal forces and moments, support forces, displacements …
Kind regards
Sabine Fahrendholz
Senior Product Manager
