Hello everyone,
I am currently analyzing and designing a building with Sofistik. The geometry and other inputs were defined through Rhino. However, I am struggling now with the column design. I am trying to incorporate the column module to get the internal forces from the analysis, and be able to check the fire resistance, creep, stability and design of each column, or group of columns (same conditions= section, height and limits). Nevertheless, the program does not work correctly, even when I have tried to design a single element.
Any ideas or suggestions?
