Change properties for multiple selected elements - Sofiplus
Basic question, but how do I change the thickness of multiple selected walls?
Don’t want to double click and change each one separately.
Hi jonfistik,
there are several ways to change more than one element in one step. Please read the SOFiPLUS documentation:
https://docs.sofistik.com/2025/en/sofiplus/working_with_autocad/ACAD/double_click.html
thanks for the reply. But is still very unclear.
Do these work also for Sofiplus 2024?
Example: I double clicked the element and picked other afterwards, but it changes only the properties of the first one.
  1. Sure, this has worked since structural elements were present in SOFiPLUS.
  2. Maybe a RETURN is missing? As you know, in AutoCAD every selection set must be completed with a RETURN. So select the other elements and end the object selection with RETURN. The number of selected elements can be checked in the footer of the dialog:
