Can't generate the results in Sofistik Plus X
I’m actually using a student license and I wanted to generate results from Sofistik Plus X. All my calculations were done successfully, however, there was nothing saved when I clicked on “Show tabular results”.
Is this related to my student license?
Thanks.
You have to select which results you want to view.
You can also go into wingraf and see results graphically. There should be a tab called ‘Results’
