Cannot read .dll files when trying to access .cdb via python
I have a script that i have been using for a long time to access .cdb via python.
But since getting a new computer, it is throwing an error.
I am using this setup:
Configure the project - CDB Interfaces 2024 (sofistik.com)
path = os.environ["Path"]
# 64bit DLLs
dllPath = r"C:\Program Files\SOFiSTiK\2024\SOFiSTiK 2024\interfaces\64bit"
dllPath += ";"
# other necessary DLLs
dllPath += r"C:\Program Files\SOFiSTiK\2024\SOFiSTiK 2024"
os.environ["Path"] = dllPath + ";" + path
# Get the DLL functions
myDLL = cdll.LoadLibrary(r"C:\Program Files\SOFiSTiK\2024\SOFiSTiK 2024\interfaces\64bit\sof_cdb_w-2024.dll")
py_sof_cdb_get = cdll.LoadLibrary("sof_cdb_w-2024.dll").sof_cdb_get
py_sof_cdb_get.restype = c_int
py_sof_cdb_kenq = cdll.LoadLibrary("sof_cdb_w-2024.dll").sof_cdb_kenq_ex
#End Region
but, now i am gettins this error:
Traceback (most recent call last):
  File "c:\Python sofistik1\samlet pakke\Sofistik_Func.py", line 29, in <module>
  File "C:\Program Files\Python313\Lib\ctypes\__init__.py", line 471, in LoadLibrary
    return self._dlltype(name)
  File "C:\Program Files\Python313\Lib\ctypes\__init__.py", line 390, in __init__
    self._handle = _dlopen(self._name, mode)
FileNotFoundError: Could not find module 'C:\Program Files\SOFiSTiK\2024\SOFiSTiK 2024\interfaces\64bit\sof_cdb_w-2024.dll' (or one of its dependencies). Try using the full path with constructor syntax.
The file “sof_cdb_w-2024.dll” is very obviously in the right location with the right name, i am thinking its something with the dependencies, but i am running out of options here. Anyone have experience with this error?
I figured it out. Even though i was using a python version newer than 3.8 with the old way of calling .dll before, i had to update to the new function for calling .dll.
Hello Morten
what was the problem i am trying to read cdb database too but i am getting errors? i am doing it via c-sharp?
It was importing some files in a different format than before. Took me forever to find the issue.
I dont know about c#, are you following this?
C# - CDB Interfaces 2023
Morten, yes i made my own console programme to read cdb based on this example
I made a sidebar with error methods
I get these errors
I unlocked the base cdb but it still doesn’t open I don’t understand what the problem is.
The methods generate the following errors.
Error: CDB cannot be read! Status: 3 (Error reading/opening CDB)
CDB path: D:\1.cdb
Use absolute path: False
Open mode: 0
Create copy: False
Reset CDB: False
File attributes: Archive
File size: 58446976 bytes
Last modified time: 03/04/2025 17:18:07
Bytes read from header: 64
First bytes of the file (ASCII): V 5.01 SOFISTIK-CDB Datenbank? ?? ?? ? Z` (
File is used by another process: False
Attempt to open CDB with mode 0
Initialisation result: 0
Attempting to open CDB with mode 1
Initialisation result: 1
Status: 3
Status value: Error reading/opening CDB
Status after flush: 3
CDB closed before next attempt
Attempt to open CDB with mode 99
Status: 3
CDB closed
Sorry, i cannot help - i am not proficient in C#.
how did you implement this in python? can i try to implement your python approach in c sharpe?
Again, i dont know about C#, but you could switch to python to access the .cdb and get data, once you have data you can run your c#.
That would require two scripts, one python for data retrival, and one in c# for data handling.
