Dear Support Team,
I am trying to add a placement using the Add Placement
function as shown in the picture, but it isn’t working. The location of the placement depends on the placement of another axis and that is why I have to use this particular function instead of going to Edit axis
and adding the placement from there.
Hello Keerthana
Could you please describe your workflow in more detail? I can’t reproduce your problem (see attached screenshot). The recommended workflow is described within the online documentary.
https://www.sofistik.de/documentation/2022/en/bridge_modeler/cmdref/create/axis.html#add-placements
Perhaps you can send us a small example of your project.
Have you installed the latest SOFiSTiK and Revit updates? Which versions are you using?
Hello Frederik,
It looks like I had’nt updated the software. It works fine now after the update. Thank you for the quick response.
