Rhino Insider is a plug-in for transfering data between Rhino and Revit.
After installing both Sofistik Rhino Interface 2022 and Rhino Insider 1.0, when running the Rhino insider in the Revit 2022, the Revit 2022 will 100% crash.
After disabling Sofistik Rhino Interface 2022 in Rhino, the Rhino insider can be run on the Revit 2022.
Just a short question. I could not recreate the program crash. I can use the Rhino Inside Revit 1.0 tool in Revit 2022 without problems. Although the SOFiSTiK Rhino Interface 2022 is installed.
Can you briefly describe your approach step by step?
Thank you very much.
Ok, I have tried your described workflow, but I still can not recreate the crash.
We think that the SOFiSTiK interface does not interfere with Rhino Inside, but that another plugin is jointly responsible.
Have you tested the crash with other plugins as well?
Or have you tried to reinstall the used programs?
