In this bridge model,
I defined 3 response spectrum in X,Y and Z and I defined action E to use (CSM bridge design superposition). The maximum and minimum values are calculated using (EXTR N 12002 STYP CQC ACT E). My question is about using CQC calculate the EQ for example direction in X and take 0.3 from y and Z or CQC option take EQ for example direction in X without adding 0.3 from y and z directions
