I am trying to calculate reinforcement in a concrete structure using BEMESS. I can see from the BEMESS report, that all the reinforcement is from crack width verification (0,2mm).
I was using “CRAC WK PARA”. However when using “CRAC WK TAB” i get completly different results.
For one element the results can be summed up as (cm2/m):
*Hand calculations are not taking normal forces into account, and are using MX=MX+MXY
I was wondering when is it recommended to use what, there seems to be quite a difference? Is it correctly understood that the difference is in using 7.3.3 or 7.3.4 in EN 1992-1-1?
Is there a way to get more detailed explanations of the calculations done in the BEMESS Report? This seems like the most detail i can get:
