I have modelled girder and deck slab composite system via beam and quad elements respectively. However weight of quad element is not reflected in the construction stage LCs in wingraph. While investigating for it, I came across an example named "csm_13_quad_weight_lar_activation.dat’. While using the method provided in the example my run time has significantly increased.
Can anyone throw some more light on the example ? and also is there any work around available? . Thankyou.
Example 'csm_13_quad_weight_lar_activation.dat’ works on my computer with Teddy 2024, calculation needs about 5 seconds.
Without an upload of your files it’s not possible to help efficiently.
