It there a way in SoFiSTiK Graphic to directly analyze beam displacement?
I’m always using nodal displacement values, but it’s quite inconvenient for large schemes.
Here I can’t see any values:
Thank you for help
Thank you for help
Hello Sigita
If the displacements in the beamsections are stored in the database, the results should be displayed. So maybe you don’t have any relevant results in your CDB?
Here is an example showing the beam displacements:
TEDDY > File > Examples > ASE > english > ase11_girder_overturning.dat
