I wanted to know if I could use the BDK module when I have a dynamic analysis of a steel structure with module DYNA. Could I check the members with load cases superposed with the MAXIMA module?
Thank you
As far as I know, BDK can only use results from ASE and STAR2 (BDK manual chapter 1 Task Description). If you are unsure about a function, please test your idea with a small example.
In addition, BDK is not able to process superimposed loadcases (e.g. MAXIMA DESI) (BDK Manual chapter 3.11 LC - Selection of the Loadcase to be Designed). Instead, use combinations in ASE with the following types:
- Comb Design (D)
- Comb Accidental (A)
- Comb Earthquake (E)
- Comb Fire (AB)
Thank you Frederik,
So I understand that it is possible to make a dynamic analysis in a steel structure. Am I right?
