I’m trying to simulate the grouting activity in TBM sequence. For that, I want to apply the grout pressure in a physical gap (shown below) in between TBM and lining. I’m using planar system with input via Teddy.
It would be nicer, if someone share the similar application examples. Capture1|204x204
Hi
Yes, I went through all the examples given into the tutorial.
Actually, I wanted to apply a pressure inside the physical gap to simulate the grouting pressure application. Basically, to capture the heaving of nearby soil (quad elements) due to pressure, if any.
Do we require Hydra module for that? if not by Sofiload
If you are not working with the educational license, I would suggest contacting the SOFiSTiK support.
Just open the SOFiSTiK Application Manager (SAM) and click on the small headset icon.
