Hi. I am trying to use the visualisation function in Revit, after analysed and designed the construction. But I am having a problem with the slab visualisation. I am not getting any results nither the button for the slab is active in the Structural properties panel. Is there anybody here who can help with this issue?
Hello Fik28,
the screenshot you are sending is displaying the reinforcement results from the CDB of the main system.
One thing you may want to check is the following:
- did you perform the design of your slab or was it only an analysis? (with a design, you would obtain reinforcement results while the analysis returns internal forces)
- is your data source the correct one? (at the moment, you are reading from a result package saved from the main system, maybe the results of your slab are stored in another data source.)
Best Regards,
Noelie Böger
