As far as i know #include works only with define blocks in the same file.
What i ussually do is to create a different dat file with the loads or prestressing or wathever, and then use +apply “filename.dat”.
In this way you can make order in very large files.
It seems you have errors in table definition.
fixed values must be at the end of the header line. Try with:
cable t pa from=grp type=vx
1 -10085
2 -1047197.323
etc…
+Apply file is read “when the calculation gets there” → you can change/update/generate the file in previous programs. However it needs to consist of “full programs” (e.g. template/ase/sofismhc/…)
"include file is read “when you push the calculation button” → can’t be altered during calculation run. Although you can just include snippets (e.g. include spt or cable in the middle of a sofimshc run)
With either one there is no read line by line.
Workaround:
